[Qgis-developer] QGIS 3.0: Plans to support librttopo?
Mark Johnson mj10777 at googlemail.com
Mon Mar 6 05:45:03 PST 2017
The spatialite function 'ST_Project' is based on the librttopo functionality
(formally LWGEOM)
- and is only available when compiled with '--enable-rttopo'
https://git.osgeo.org/gogs/rttopo/librttopo
So if a support for 'Meters as Map units' was desired, in the case of
degrees
- the use the librttopo functionality as a part of the 'QgsGeos' would be
the most effective way to deal with this
This would be a new dependency, but would also offer many other
functionalities (such as Topology).
Mark Johnson, Berlin Germany
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170306/7eb0c5f6/attachment.html>
