[Qgis-developer] PyQgsServerTest :: test_wms_getprint_srs disabled
Matthias Kuhn matthias at opengis.ch
Mon Mar 6 08:45:05 PST 2017
Hi Paul,
On 03/06/2017 05:30 PM, Paul Blottiere wrote:
> Hi Alessandro,
>>> can you please have a look?
>>> I'm afraid this failure is not a problem in the test itself but a
>>> symptom of more serious issue: the map is completely missing from the
>>> generated print.
>> FYI, the same test also fails on 2.14 as discussed on the following
>> commit:
> I took a look but I cannot reproduce the failing test
> test_wms_getprint_srs.
> Actually, I have tested it within the next environment without issues:
> - master on Debian
> - release-2_14 on Ubuntu.
The test also only failed one out of 30 times on travis, so I guess it's
a tricky one to get a lead.
I'd recommend to run it in a loop locally and see if you can reproduce
it this way.
If you really don't find a way to reproduce this locally but have some
suspicion, you can also introduce some additional tests or debug output
that might help to assess the problem and re-enable the test on travis.
This way at least we have more information on travis the next time it fails.
Bests
Matthias
