[Qgis-developer] Housekeeping in the (Qgs)Settings
Richard Duivenvoorde
rdmailings at duif.net
Tue Mar 7 00:38:49 PST 2017
Hi Ale,
yep agreed! And now (while most users do not have real 3.0
configs/settings) is the only time to do this...
as people will loose all connections etc etc
I would even be ok, to use python style names, so no capitals and use of
underscores:
/BetterAttributeTable/geometry
becomes
better_attribute_table/geometry
etc etc
Let's clean up :-)
Regards,
Richard
On 2017-03-06 11:05, Alessandro Pasotti wrote:
> Hi,
> the current keys naming for the settings is not very consistent, what
> do you guys think about cleaning it a bit?
> I was thinking at:
> 1. adding an 'app' section to QgsSettings::Section enum, to store
> namespaced settings for the application
> 2. remove the '/' at the beginning of the keys (it's completely
> unuseful)
> 3. enforce namespacing with the use of Sections on all keys used in
> the '/src/*' folders
> This is a quick grep|sort|uniq of the setting keys:
> allowGeometrylessTables
> /browser/favourites
> /browser/hiddenPaths
> cache/directory
> cache/size
> /colors/palettecolors
> /colors/palettelabels
> /colors/recent
> /ColorWidgets/textWidgetFormat
> /Composer/defaultFont
> /Composer/defaultSnapGridOffsetX
> /Composer/defaultSnapGridOffsetY
> /Composer/defaultSnapGridResolution
> /Composer/defaultSnapTolerancePixels
> /Composer/geometry
> composer/searchPathsForTemplates
> /ComposerUI/state
> CptCity/archiveName
> CptCity/baseDir
> crs
> database
> /dataitem/directoryHiddenColumns
> /Db2/connections/selected
> dboptions
> dbworkspace
> Digitizing
> /digitizing/simplify_tolerance
> /digitizing/simplify_tolerance_units
> dpiMode
> /Error/dialog/detail
> estimatedMetadata
> /eVis/browser-geometry
> /eVis/db-geometry
> fontFamily
> /fontFamily
> fontPointSize
> /fontPointSize
> geometryColumnsOnly
> /gps/lastPort
> /GradientEditor/plotAlpha
> /GradientEditor/plotHue
> /GradientEditor/plotLightness
> /GradientEditor/plotSaturation
> /GRASS/browser/import/crsTransform
> /GRASS/browser/import/external
> /GRASS/gidbase/custom
> /GRASS/gidbase/customDir
> /GRASS/lastDirectOutputDir
> /GRASS/lastGisdbase
> /GRASS/lastLocation
> /GRASS/lastMapset
> /GRASS/modules/config/custom
> /GRASS/modules/config/customDir
> /GRASS/modules/debug
> /GRASS/newMapsetWizard/openMapset
> /GRASS/region/color
> /GRASS/region/on
> /GRASS/region/width
> /GRASS/showTopoLayers
> /GRASS/windows/tools/geometry
> groupBoxCustom
> help/helpSearchPath
> /HelpViewer/geometry
> /HistogramWidget/showMean
> /HistogramWidget/showStdev
> host
> iconSize
> /IconSize
> ignoreAxisOrientation
> ignoreGetFeatureInfoURI
> ignoreGetMapURI
> invertAxisOrientation
> lastColorMapDir
> locale
> locale/overrideFlag
> locale/userLocale
> /Map/highlight/buffer
> /Map/highlight/color
> /Map/highlight/colorAlpha
> /Map/highlight/minWidth
> /Map/identifyMode
> /Map/logCanvasRefreshEvent
> Map/scales
> /Map/searchRadiusMM
> /MSSQL/connections/selected
> /ogr/connections/selectedtype
> /osm/lastDir
> password
> path
> /Plugin-GeoReferencer/lastcompression
> /Plugin-GeoReferencer/lastPDFReportDir
> /Plugin-GeoReferencer/lastresampling
> /Plugin-GeoReferencer/lasttransformation
> /Plugin-GeoReferencer/loadinqgis
> /Plugin-GeoReferencer/targetsrs
> /Plugin-GeoReferencer/TransformSettingsWindow/geometry
> /Plugin-Georeferencer/user_specified_resolution
> /Plugin-GeoReferencer/user_specified_resx
> /Plugin-GeoReferencer/user_specified_resy
> /Plugin-Georeferencer/word_file_checkbox
> /Plugin-GeoReferencer/zeroastrans
> /Plugin-GPS/devicelist
> /Plugin-GPS/geometry
> /Plugin-GPS/gpsbabelpath
> /Plugin-GPS/gpxdirectory
> /Plugin-GPS/importdirectory
> /Plugin-GPS/lastdldevice
> /Plugin-GPS/lastdlport
> /Plugin-GPS/lastImportFilter
> /Plugin-GPS/lastTab
> /Plugin-GPS/lastuldevice
> /Plugin-GPS/lastulport
> Plugin-OfflineEditing/geometry
> Plugin-OfflineEditing/offline_data_path
> plugins/searchPathsForPlugins
> port
> /PostgreSQL/connections/selected
> previewImage
> /Projections/defaultBehavior
> /Projections/layerDefaultCrs
> /Projections/otfTransformEnabled
> /Projections/projectDefaultCrs
> /Projections/showDatumTransformDialog
> proxy/proxyEnabled
> proxy/proxyExcludedUrls
> proxy/proxyHost
> proxy/proxyPassword
> proxy/proxyPort
> proxy/proxyType
> proxy/proxyUser
> pythonConsole/fontfamilytextEditor
> pythonConsole/fontsizeEditor
> /qgis/addDb2DC
> /qgis/addMSSQLDC
> /qgis/addPostgisDC
> qgis/askToSaveProjectChanges
> /qgis/attributeTableBehavior
> /qgis/attributeTableLastView
> /qgis/attributeTableRowCache
> /qgis/attributeTableView
> /qgis/capitalizeLayerName
> /qgis/checkVersion
> /Qgis/connections-wms/selected
> /qgis/copyFeatureFormat
> /qgis/copyGeometryAsWKT
> /qgis/default_canvas_color_blue
> /qgis/default_canvas_color_green
> /qgis/default_canvas_color_red
> /qgis/default_measure_color_blue
> /qgis/default_measure_color_green
> /qgis/default_measure_color_red
> /qgis/default_selection_color_alpha
> /qgis/default_selection_color_blue
> /qgis/default_selection_color_green
> /qgis/default_selection_color_red
> /qgis/digitizing/default_snap_enabled
> /qgis/digitizing/default_snap_mode
> /qgis/digitizing/default_snapping_tolerance
> /qgis/digitizing/default_snapping_tolerance_unit
> /qgis/digitizing/disable_enter_attribute_values_dialog
> /qgis/digitizing/fill_color_alpha
> /qgis/digitizing/fill_color_blue
> /qgis/digitizing/fill_color_green
> /qgis/digitizing/fill_color_red
> /qgis/digitizing/line_color_alpha
> /qgis/digitizing/line_color_alpha_scale
> /qgis/digitizing/line_color_blue
> /qgis/digitizing/line_color_green
> /qgis/digitizing/line_color_red
> /qgis/digitizing/line_ghost
> /qgis/digitizing/line_width
> /qgis/digitizing/marker_only_for_selected
> /qgis/digitizing/marker_size
> /qgis/digitizing/marker_style
> /qgis/digitizing/reuseLastValues
> /qgis/digitizing/search_radius_vertex_edit
> /qgis/digitizing/search_radius_vertex_edit_unit
> /qgis/digitizing/validate_geometries
> /qgis/dockAttributeTable
> /qgis/enableMacros
> /qgis/enableMapTips
> Qgis/helpQgisHomePageUrl
> /qgis/ignoreShapeEncoding
> /qgis/legendDoubleClickAction
> /qgis/live_color_dialogs
> /qgis/magnifier_factor_default
> /qgis/measure/angleunits
> /qgis/measure/decimalplaces
> /qgis/measure/displayunits
> /qgis/measure/keepbaseunit
> /qgis/messageTimeout
> /qgis/native_color_dialogs
> /qgis/new_layers_visible
> /qgis/newProjectDefault
> /qgis/overwriteStyle
> /qgis/projectTemplateDir
> /qgis/projOpenAtLaunch
> /qgis/projOpenAtLaunchPath
> /qgis/projOpenedOKAtLaunch
> /qgis/promptForRasterSublayers
> /qgis/promptForSublayers
> Qgis/QgisApiUrl
> Qgis/reportaBugUrl
> /qgis/scanItemsFastScanUris
> /qgis/scanItemsInBrowser2
> /qgis/scanZipInBrowser2
> /qgis/segmentationTolerance
> /qgis/segmentationToleranceType
> /qgis/showLegendClassifiers
> /qgis/showTips%1
> /qgis/simplifyAlgorithm
> /qgis/simplifyDrawingHints
> /qgis/simplifyDrawingTol
> /qgis/simplifyLocal
> /qgis/simplifyMaxScale
> qgis/stylesheet/groupBoxCustom
> Qgis/supportProvidersUrl
> /qgis/warnOldProjectVersion
> /qgis/wheel_action
> /qgis/WMSSearchUrl
> /qgis/zoom_factor
> /Raster/defaultPalette
> /Raster/histogram/drawLines
> /Raster/histogram/showMarkers
> /Raster/histogram/updateStyleToMinMax
> /Raster/histogram/zoomToMinMax
> referer
> savePassword
> saveUsername
> service
> smoothPixmapTransform
> /SpatiaLite/connections/%1/sqlitepath
> /SpatiaLite/connections/selected
> SpatialQuery/geometry
> sslmode
> /StatisticalSummaryDock/checked_%1
> /StatisticalSummaryDock/checked_missing_values
> style/lastStyleDir
> svg/searchPathsForSVG
> /Themes
> title
> /UI/annotationTool
> UI/autoApplyStyling
> /UI/ComposerManager/templatePath
> /UI/Customization/enabled
> /UI/defaultAddDbLayerAction
> /UI/defaultFeatureService
> /UI/defaultMapService
> /UI/defaultMoveTool
> /UI/defaultNewLayer
> /UI/defaultPointSymbolAction
> /UI/encoding
> /UI/geometry
> UI/lastAuthImportBundleOpenFileDir
> UI/lastAuthImportCertOpenFileDir
> UI/lastAuthImportSslOpenFileDir
> UI/lastAuthOpenFileDir
> /UI/lastComposerTemplateDir
> /UI/lastExternalResourceWidgetDefaultPath
> UI/lastMatchToSymbolsDir
> /UI/lastProjectDir
> /UI/lastRasterFileDir
> /UI/lastSaveAsImageDir
> /UI/lastSaveAsImageFilter
> /UI/lastSaveAsSvgFile
> /UI/lastSpatiaLiteDir
> /UI/lastSVGMarkerDir
> /UI/LastUsedDirectory
> /UI/lastVectorFileFilterDir
> /UI/lastVectorFormat
> /UI/measureTool
> /UI/missingDirectory
> /UI/recentProjections
> /UI/recentProjectionsAuthId
> /UI/recentProjectionsProj4
> /UI/recentProjectsList
> /UI/selectTool
> /UI/state
> /UI/styleUndoMergeTimeout
> /UI/tileScaleEnabled
> UI/UITheme
> url
> username
> userTablesOnly
> /variables/names
> /variables/values
> wfs/max_feature_count_if_not_provided
> /Windows/AttributeSelectionDialog/geometry
> /Windows/BetterAttributeTable/geometry
> /Windows/Bookmarks/geometry
> /Windows/Bookmarks/headerstate
> /Windows/Bookmarks/LastUsedDirectory
> /Windows/ChangeLabelProps/geometry
> /Windows/ColorDialog/activeComponent
> /Windows/ColorDialog/activeScheme
> /Windows/ColorDialog/activeTab
> /Windows/ColorDialog/customColor1
> /Windows/ColorDialog/customColor10
> /Windows/ColorDialog/customColor11
> /Windows/ColorDialog/customColor12
> /Windows/ColorDialog/customColor13
> /Windows/ColorDialog/customColor14
> /Windows/ColorDialog/customColor15
> /Windows/ColorDialog/customColor16
> /Windows/ColorDialog/customColor2
> /Windows/ColorDialog/customColor3
> /Windows/ColorDialog/customColor4
> /Windows/ColorDialog/customColor5
> /Windows/ColorDialog/customColor6
> /Windows/ColorDialog/customColor7
> /Windows/ColorDialog/customColor8
> /Windows/ColorDialog/customColor9
> /Windows/ColorDialog/geometry
> /Windows/ColorDialog/sampleRadius
> /Windows/ComposerImageExportOptionsDialog/geometry
> /Windows/ComposerManager/geometry
> /Windows/ComposerTableBackgroundColorsDialog/geometry
> /Windows/CptCityColorRampV2Dialog/geometry
> /Windows/CptCityColorRampV2Dialog/splitter
> /Windows/CustomProjection/geometry
> /Windows/DatumTransformDialog/columnWidths/%1
> /Windows/DatumTransformDialog/geometry
> /Windows/DatumTransformDialog/hideDeprecated
> /Windows/DatumTransformDialog/rememberSelection
> /Windows/Db2SourceSelect/columnWidths/%1
> /Windows/Db2SourceSelect/geometry
> /Windows/Db2SourceSelect/HoldDialogOpen
> /Windows/DecorationCopyright/geometry
> /Windows/DecorationNorthArrow/geometry
> /Windows/DecorationScaleBar/geometry
> /Windows/Diagrams/OptionsSplitState
> /Windows/Diagrams/Tab
> /Windows/EmbedLayer/geometry
> /Windows/ExpressionBuilderDialog/geometry
> /Windows/ExpressionSelectionDialog/geometry
> /Windows/GradientEditor/geometry
> /Windows/Labeling/FontPreviewSplitState
> /Windows/Labeling/OptionsSplitState
> /Windows/Labeling/Tab
> /Windows/loadStyleFromDb/geometry
> /Windows/Measure/geometry
> /Windows/Measure/h
> /Windows/Measure/hNoTable
> /Windows/MergeAttributes/geometry
> /Windows/MessageViewer/geometry
> /Windows/MSSQLSourceSelect/columnWidths/%1
> /Windows/MSSQLSourceSelect/geometry
> /Windows/MSSQLSourceSelect/HoldDialogOpen
> /Windows/NewGeoPackageLayer/geometry
> /Windows/NewMemoryLayer/geometry
> /Windows/NewSpatiaLiteLayer/geometry
> /Windows/NewVectorLayer/geometry
> /Windows/OGRDatabaseConnection/geometry
> /Windows/OpenVectorLayer/geometry
> /Windows/PgSourceSelect/columnWidths/%1
> /Windows/PgSourceSelect/geometry
> /Windows/PgSourceSelect/HoldDialogOpen
> /Windows/PluginManager/secondSplitterState
> /Windows/ProjectionSelector/geometry
> /Windows/QgsAttributeTypeDialog/geometry
> /Windows/QgsDelAttrDialog/geometry
> /Windows/QgsExpressionBuilderWidget/editorsplitter
> /Windows/QgsExpressionBuilderWidget/functionsplitter
> /Windows/QgsExpressionBuilderWidget/splitter
> /Windows/QgsFieldCalculator/geometry
> /Windows/QgsGrassNewMapset/geometry
> /Windows/QgsOrganizeTableColumnsDialog/geometry
> /Windows/QgsRendererRulePropsDialog/geometry
> /Windows/QueryBuilder/geometry
> /Windows/RasterCalc/geometry
> /Windows/saveStyleToDb/geometry
> /Windows/SelectByForm/geometry
> /Windows/ShortcutsDialog/geometry
> /Windows/SourceSelectDialog/geometry
> /Windows/SourceSelectDialog/UseTitleLayerName
> /Windows/SpatiaLiteSourceSelect/geometry
> /Windows/SpatiaLiteSourceSelect/HoldDialogOpen
> /Windows/StyleV2Manager/geometry
> /Windows/StyleV2Manager/splitter
> /Windows/SvgSelectorDialog/geometry
> /Windows/SvgSelectorWidget/RelativePath
> /Windows/symbolLevelsDlg/geometry
> /Windows/SymbolSelectorWidget/geometry
> /Windows/TextFormatDialog/geometry
> /Windows/VectorLayerSaveAs/geometry
> /Windows/WFSSourceSelect/FeatureCurrentViewExtent
> /Windows/WFSSourceSelect/geometry
> /Windows/WFSSourceSelect/HoldDialogOpen
> /Windows/WFSSourceSelect/UseTitleLayerName
> /Windows/WMSSourceSelect/geometry
> /Windows/WMTSDimensions/geometry
> zmax
> zmin
> Alessandro Pasotti
> w3: www.itopen.it [1]
> Links:
> [1] http://www.itopen.it
> Qgis-developer mailing list
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
