[Qgis-developer] R in Processing: errors not shown
Paolo Cavallini
cavallini at faunalia.it
Wed Mar 15 00:17:55 PDT 2017
Il 13/03/2017 15:17, matteo ha scritto:
>> this did not happen in my case
> ok, not sure if this is related to this mandatory R packages
>> after installing them, the error is gone, and the entries appear on the list
> ok, do you have ggplot2 installed? If not, try to import the attached
> script (copy and paste the content in the editor) and try to use it
> if it works and you did not had ggplot2 installed then Processing is
> able to install additional packages, if not, then I'm totally wrong :)
Tested: it runs, but fails because it does not find the function
scale_y_continuous, so I suppose it does not install ggplot2.
Thanks.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
https://www.google.com/trends/explore?date=all&geo=IT&q=qgis,arcgis
