[Qgis-developer] Corrections of QgsOgrProvider implementaion of GDAL 2.0
Even Rouault
even.rouault at spatialys.com
Mon Mar 20 15:39:19 PDT 2017
> The proposed solution deals with problem in QgsOgrProvider::subLayers()
> - searches for duplicate names
> -- an extra parameter tells QgsOgrProvider if the given id or layername
> should be used
Perhaps we can avoid that extra parameter, and have the layer name prioritary over the layer
id when both are found ?
> - default layername, otherwise id
> All of this is stored in the URI for the project.
> This was tested with the KML where the problem was reported
> - it was then that the layername was removed (i.e. is no longer sent to
> QgsOgrProvider by subLayers()) last June
Not sure to what you are refering too, since I can see the layerName returned here:
https://github.com/qgis/QGIS/blob/master/src/providers/ogr/qgsogrprovider.cpp#L700
> On top of that, we need to add an extra argument to store the geometry
> > column name in the URI and in the output of subLayers().
> The layername is also needed for the display in QGIS
The layer name can be stored in subLayers() for conveniency, since it has usually a short life.
And for subLayers() / askUserForOGRSublayers() make the layer id what is used.
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170320/47637918/attachment.html>
