[Qgis-developer] Corrections of QgsOgrProvider implementaion of GDAL 2.0
Mark Johnson
mj10777 at googlemail.com
Mon Mar 20 16:01:35 PDT 2017
> The layer name can be stored in subLayers() for conveniency, since it has
>> usually a short life. And for subLayers() / askUserForOGRSublayers() make
>> the layer id what is used.
> subLayers is not used when read from a project, only when a new source is
added.
>> Not sure to what you are refering too, since I can see the layerName
>> returned here:
> Between subLayers() and QgsOgrProvider the data runs through other
functions in other classes
- in one the layername is removed
void QgisApp::askUserForOGRSublayers( QgsVectorLayer *layer )
Q_FOREACH ( const QgsSublayersDialog::LayerDefinition& def,
chooseSublayersDialog.selection() )
QString layerGeometryType = def.type;
- QString composedURI = uri + "|layerid=" + QString::number(
def.layerId );
+ QString composedURI = uri + "|layerid=" + QString::number(
def.layerId ) + "|layername=" + def.layerName;
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170321/84717e2e/attachment.html>
