[Qgis-developer] Corrections of QgsOgrProvider implementaion of GDAL 2.0
Mark Johnson
mj10777 at googlemail.com
Tue Mar 21 02:34:32 PDT 2017
> So if both a layerid and layername, you would prever layerid over
> layername ?
no, the other way around
Default: layername, only when a duplicate layername exists, should the id
be used
Checking for duplicate names is done in subLayers()
- if layername is unique, id will be set to -1 and sent to QgsOgrProvider
QgsOgrProvider would
- use GDALDatasetGetLayer if id >= 0
otherwise
- use GDALDatasetGetLayerByName
To solve the issue of several geometry fields we also need a (optional)
> parameter with the geometry column name.
subLayers() will send the layer name in the 'table_name(field_name)' format
It was only with gdal 1 that GDALDatasetGetLayerByName could not use that
format.
That means the 'table_name(field_name)' format can always be used.
>From a robustness point of view, I think we should be robust to layerid
> being absent from the
> URI (and I'd prefer that when we generate URI, we don't set layerId = -1
> but just remove it)
> since URIs can also been built by users and not only through the UI.
Since it is not a mandatory parameter inside QgsOgrProvider where the
string is being parsed, the default value of -1 will be used.
- so there is no need to store a -1 value in the project.
> We shoud also be robust
> to layername from being absent as well, as done currently.
Yes, also not a mandatory parameter
- at the moment QgisApp::askUserForOGRSublayers removes the layername sent
by, so everything also works without a layername being sent.
I have started a manual merge into the QGIS 3 version, making sure that the
many changes are not disturbed.
Also all gdal 1 switches and the '>= GDAL_COMPUTE_VERSION(2,0,0)' will be
removed.
So I hope to offer a QGIS 3 pull request in the next few days.
I would also like to adapt QgsOgrProvider::ogrWkbGeometryTypeName
- to use QgsWkbTypes::displayString first
and only when not found to check for geometry types not supported by qgis
when needed.
ogrWkbGeometryTypeFromName must remain, since there is no corresponding
function in QgsWkbTypes.
Mark
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170321/3332756d/attachment.html>
