[Qgis-developer] Adding default OSM backround maps
Mathieu Pellerin nirvn.asia at gmail.com
Tue Mar 21 20:11:00 PDT 2017
Tim,
-1 to use OSM-based XYZ tile server that doesn't update its dataset on a
regular basis (+/- weekly). While there are nicer styles that OSM's default
one, one of the fundamental dynamic of OSM is the ability to update / add
spatial data and see those updates reflected on tiles immediately. We
should both respect and benefit from that :)
For e.g., the beautiful style on the link you provided uses a 10-month old
OSM dataset. It's a significant data gap.
Math
On Wed, Mar 22, 2017 at 2:29 AM, Tim Sutton <tim at kartoza.com> wrote:
> Hi
> Its really great to see this Paolo. I think the OSM requests all sound
> reasonable and if we do start representing a high load on their servers we
> could consider adding a caching proxy between QGIS clients and OSM tile
> server so that we don't hit their servers too hard.
> One thing that I would suggest is that we do not use the default tile
> renders for OSM - it would be much nicer to provide something 'consumer'
> orientated rather than the OSM renders which are great for visualizing a
> broad range of OSM feature types but not IMHO very nice looking
> cartography. Reaching out to the folks at http://giscience.uni-hd.de to
> see if we can use their tile renders might provide a nicer out of the box
> experience for our users. Of course we would still acknowledge OSM as the
> source of the data and giscience as source of the renders. Here is an
> example of their render:
> *http://korona.geog.uni-heidelberg.de
> <http://korona.geog.uni-heidelberg.de>*
> Regards
> Tim
> On 21 Mar 2017, at 4:58 PM, Jorge Gustavo Rocha <jgr at di.uminho.pt> wrote:
> Hi Paolo,
> I can help on this.
> 1. The UserAgent is already a configurable feature in QGIS (under
> Options/Network). Any user can change it, but we can propose another
> default value.
> 2. The QGIS community is very much aware of OpenStreetMap. If we really
> need to make our users more aware, does it make sense to add a new
> button to QGIS to report map errors? (context dependent, when the
> OpenStreetMap layer is shown) It would have the same functionality of
> the notes in OpenStreetMap web interface.
> 3.1 On the "add layer" dialog, we can show the OpenStreetMap url (which
> might change over time) and licenses (for data and tiles) taken from
> settings or an (external) resource. We can make this not hard coded, to
> be modified easily, without upgrading QGIS. We can also check if the
> service is enabled for us, before allow users to add that layer (related
> with 4.).
> 3.2 When the tiles are used in the composer or on the web client, we can
> not enforce an attribution string. We might add or suggest it, but users
> should be free the create and edit the attributions. It the
> responsibility of the user, not a QGIS responsibility.
> 4. We have to handle when tiles are not loading, either because there
> are network problems, server busy, etc. We can customize the user's
> feedback regarding the load of the default OpenStreetMap tiles. But we
> definitely need to know formally when they shut our access down. This is
> related with 3.1 issue. If the access is disabled, we can also disable
> adding default OpenStreetMap tiles option.
> Regards,
> Jorge Gustavo
> Às 09:52 de 21-03-2017, Paolo Cavallini escreveu:
> Hi all,
> we have been exploring the possibility of adding default XYZ maps to
> QGIS, so to make life far easier for users.
> The good news is that the OSM board is quite positive about this.
> The not-so-good news is that their (I believe reasonable) requirements
> imply some more development from our side.
> Is anyone interested in taking this?
> Requirements below.
> All the best.
> 1. You seem to be using an user agent of "Mozilla/5.0 QGIS/2.18.3". We
> strongly recommend that you don't pretend to be a browser by adding the
> "Mozilla" bit. OpenStreetMap sees increasing traffic from "fake" user
> agents, and it is likely that we will penalise user agents like that at
> some point in the future - meaning tiles will still be served, but
> slower than to "honest" user agents that don't pretend to be a browser
> when they are not. We understand that this is difficult terrain and that
> other data sources might actually *require* that you pretend to be a
> browser - perhaps per-datasource overrides of the user agent are a
> possibility.
> 2. As you know, OpenStreetMap thrives on contributions by mappers, and
> one of the main reasons we make our tiles freely available is the hope
> of attracting new contributors. It would be nice if QGIS could do its
> part to help us here, by making their users aware that OSM is open for
> everyone to contribute. Perhaps a link to
> http://www.openstreetmap.org/fixthemap can be placed somewhere in the
> layer description or something.
> 3. Our data is licensed under ODbL 1.0, and our map tiles are CC-BY-SA
> 2.0. The latter could change at any time; the former is
> relatively constant.
> The legal consequences of this situation for your users are:
> * If they publish an image in which our tiles are visible, they must
> attribute OpenStreetMap as the source, and specify that the map image is
> CC-BY-SA 2.0, and specify that the data behind it is ODbL 1.0. All these
> requirements can be fulfilled in one go by linking to
> www.openstreetmap.org/copyright but there is no legal requirement to
> link to that page.
> * Everyone is allowed to create derivatives of OpenStreetMap data - for
> example by tracing features on the OSM tiles - and freely distribute
> them. Such derived datasets, unless they are "insubstantial"
> (https://wiki.osmfoundation.org/wiki/Licence/Community_
> Guidelines/Substantial_-_Guideline)
> inherit the ODbL license and must, when publicly used, on request be
> made available under ODbL.
> 4. If the load coming from QGIS should be unexpectedly high and impact
> our service performance, there might come a time where we'd have to
> throttle or even switch off this access. You should have some mechanism
> or plan that deals with that to avoid frustration among your user base -
> maybe a mechanism where QGIS installations request updated tile sources
> from a central service so you could notify them of the OSM tiles not
> being available (or being available elsewhere) should the need arise.
> J. Gustavo
> Jorge Gustavo Rocha
> Departamento de Informática
> Universidade do Minho
> 4710-057 Braga
> Tel: +351 253604480 <+351%20253%20604%20480>
> Fax: +351 253604471 <+351%20253%20604%20471>
> Móvel: +351 910333888 <+351%20910%20333%20888>
> skype: nabocudnosor
> Qgis-developer mailing list
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> *Tim Sutton*
> *Co-founder:* Kartoza
> *Project chair:* QGIS.org
> Visit http://kartoza.com to find out about open source:
> Desktop GIS programming services
> Geospatial web development
> GIS Training
> Consulting Services
> *Skype*: timlinux
> *IRC:* timlinux on #qgis at freenode.net
> Kartoza is a merger between Linfiniti and Afrispatial
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170322/eea32c29/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170322/eea32c29/attachment-0001.jpg>
