[Qgis-developer] Adding default OSM backround maps
Paolo Cavallini cavallini at faunalia.it
Wed Mar 22 03:42:52 PDT 2017
Hi Jorge,
thanks for taking this.
Il 21/03/2017 15:58, Jorge Gustavo Rocha ha scritto:
> 1. The UserAgent is already a configurable feature in QGIS (under
> Options/Network). Any user can change it, but we can propose another
> default value.
thanks - so, which could be the right default?
> 2. The QGIS community is very much aware of OpenStreetMap. If we really
> need to make our users more aware, does it make sense to add a new
> button to QGIS to report map errors? (context dependent, when the
> OpenStreetMap layer is shown) It would have the same functionality of
> the notes in OpenStreetMap web interface.
sounds good to me, and I assume also for OSM board
> 3.1 On the "add layer" dialog, we can show the OpenStreetMap url (which
> might change over time) and licenses (for data and tiles) taken from
> settings or an (external) resource. We can make this not hard coded, to
> be modified easily, without upgrading QGIS. We can also check if the
> service is enabled for us, before allow users to add that layer (related
> with 4.).
sounds good
> 3.2 When the tiles are used in the composer or on the web client, we can
> not enforce an attribution string. We might add or suggest it, but users
> should be free the create and edit the attributions. It the
> responsibility of the user, not a QGIS responsibility.
sounds good to me, have to check with OSM
> 4. We have to handle when tiles are not loading, either because there
> are network problems, server busy, etc. We can customize the user's
> feedback regarding the load of the default OpenStreetMap tiles. But we
> definitely need to know formally when they shut our access down. This is
> related with 3.1 issue. If the access is disabled, we can also disable
> adding default OpenStreetMap tiles option.
it makes sense to me
so, Jorge, would you like to help with coding this?
all the best, and thanks.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
https://www.google.com/trends/explore?date=all&geo=IT&q=qgis,arcgis
