[Qgis-developer] Wiki page/area for 'Building QGIS from scratch'
Mark Johnson mj10777 at googlemail.com
Wed Mar 22 10:51:27 PDT 2017
> Python support will be disabled.
I assume that these errors came from QGIS3-Dialog: correct?
That would mean that QGIS3 has found all of the libQt5* it needs
- and thus all paths are correct
The used python3 calls
- /usr/local/lib/python3.5/dist-packages/PyQt5/QtCore.so
so the pythonpath should also be correctly set.
So the question is why python3 cannot find them.
What does
ldd /usr/local/lib/python3.5/dist-packages/PyQt5/QtCore.so | grep libQt5
return?
The result should look similer to the result shown here:
https://github.com/qgis/QGIS-Documentation/wiki/QGIS3-lddtree-sh#pyqt5_fails
and there should be no 'not found' messages.
Printing out the PATH, LD_LIBRARY_PATH, PYTHONPATH,  and PYTHONHOME, might
also be helpful.
echo $PATH;
echo $LD_LIBRARY_PATH;
echo $PYTHONPATH;
echo $PYTHONHOME;
Mark
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170322/1248151f/attachment.html>
