[Qgis-developer] Plugin upload required fields
Alessandro Pasotti
apasotti at gmail.com
Sun Mar 26 09:23:15 PDT 2017
Hi Matthias
I'm not sure what you mean by
3.0 repo, but if it is the official repo both fields are optional according
to
http://docs.qgis.org/testing/en/docs/pyqgis_developer_
cookbook/plugins.html#plugin-metadata
Keep in mind that the xmls are cached and regenerated every 30 minutes.
If you still find an issue with that metadata please file a ticket and
attach the plugin.
Cheers
On 26 Mar 2017 4:03 p.m., "Matthias Kuhn" <matthias at opengis.ch> wrote:
Hi all,
I uploaded a new plugin to the 3.0 repository some days ago and it
wouldn't show up in the plugin list. I first suspected something related
to min/max version but it turned out, that I had to add (at least one
of) the keys experimental and deprecated to make it be listed.
I remember that I was first asked to fill in some required fields at
some point (tracker, repository...) I wonder if these fields should also
go in there - or if they should really be made optional.
Thanks
Matthias
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170326/433dce06/attachment.html>
