[Qgis-developer] overload closeEvent in AlgorithmDialog.py
Arnaud Morvan
arnaud.morvan at camptocamp.com
Mon Mar 27 00:28:35 PDT 2017
Hello Enrico,
Do not change the common dialog closeEvent Method, you should subclass it.
class MyCustomDialog(AlgorithmDialog):
You can give a custom dialog to you algorithm using
GeoAlgorithm.getCustomParametersDialog method.
class MyAlgorithm(GeoAlgorithm):
def getCustomParametersDialog(self):
return MyCustomDialog()
Do not forget to call the base AlgorithmDialog.closeEvent method in yours :
def closeEvent(self):
super(MyCustomDialog, self).closeEvent()
This is the way to execute custom tasks in the closeEvent, I do not say
that this the better way for your job.
Cheers
Arnaud Morvan
Ingénieur logiciel
Tél: +33 (0)4 58 48 20 32
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac Cedex
http://www.camptocamp.com
Le 23/03/2017 à 18:14, enrico chiaradia a écrit :
> Dear (processing) developers,
> for my plugin (IO Geopaparazzi), I need to stop the execution of an
> external thread when the user presses the X button of the form.
> I though to overload the closeEvent in this way:
> from processing.gui.AlgorithmDialog import AlgorithmDialog
> [omitted]
> class ExportTilesAlgorithm(GeoAlgorithm):
> [omitted]
> # get the AlgorithmDialog dialog object and overload the closeEvent
> AlgorithmDialog.closeEvent = self.closeEvent
> [omitted]
> def closeEvent(self, evt):
> # necessary to close the thread before it is finished
> self.workThread.stop()
> it works perfectly but I'm not sure that it will not induce anomalous
> behaviours in other geoalgorithms as the original function is (from
> AlgorithmDialog.py) :
> QgsMapLayerRegistry.instance().layerWasAdded.disconnect(self.mainWidget.layerAdded)
> QgsMapLayerRegistry.instance().layersWillBeRemoved.disconnect(self.mainWidget.layersWillBeRemoved)
> super(AlgorithmDialog, self).closeEvent(evt)
> Any suggestions?
> Thank you
> enrico
> Qgis-developer mailing list
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170327/756e4b7e/attachment.html>
