[Qgis-developer] gdalogr-Processing in QGIS 3.0
EZUSoft qgis at makobo.de
Mon Mar 27 07:56:13 PDT 2017
thanks for answer.
processing.runalg('gdal:convertformat'  ...
This works (in the principle).
Greatings Mike
> DelazJ <delazj at gmail.com> hat am 27. März 2017 um 10:41 geschrieben:
> Hi,
> It's because gdalogr no longer exists in 3.0, use instead gdal. You could to run processing.alglist() to get the write syntax of functions.
> Regards,
> Harrissou
> 2017-03-27 9:05 GMT+02:00 EZUSoft <qgis at makobo.de>:
> > Hi @all,
> >  i can not use the "gdalogr"-Processing in QGIS 3.0 (2.99) QGIS code revision 1182816
> >  import processing
> >  processing.runalg('gdalogr:convertformat','', 0, '' ,'')
> >  Error: Algorithm not found
> >  Does anyone know whats going wrong?
> >  Greatings Mike
> >  Qgis-developer mailing list
> >  Qgis-developer at lists.osgeo.org
> >  List info: [https://lists.osgeo.org/mailman/listinfo/qgis-developer](https://lists.osgeo.org/mailman/listinfo/qgis-developer)
> >  Unsubscribe: [https://lists.osgeo.org/mailman/listinfo/qgis-developer](https://lists.osgeo.org/mailman/listinfo/qgis-developer)
