[Qgis-developer] Disable control rendering order
Matthias Kuhn
matthias at opengis.ch
Tue Mar 28 12:02:45 PDT 2017
Hi Frank,
Sorry I cannot reproduce this behavior.
When I start QGIS it's unchecked and also when actively checking it and
then creating a new project it's unchecked.
This should always be turned off by default, so there is no option that
you didn't find, but possibly an issue. We just need to find out what
triggers it for you that is different here.
Matthias
On 3/27/17 9:30 PM, Frank Sokolic wrote:
> Hi all,
> In QGIS Master the "Control rendering order" in the "Layer Order Panel" is now always ticked by default when I start QGIS. Is there any way to disable this so that it is off by default? I've looked in settings and can't see how to do this.
> I'm running QGIS Master on Ubuntu 16.10.
> Regards, Frank.
> Qgis-developer mailing list
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
