[Qgis-developer] automatic sip files generation
Matthias Kuhn
matthias at opengis.ch
Thu Mar 30 08:08:14 PDT 2017
Hi Denis,
Thanks a lot for finishing this.
I am really excited and expect less troubles on the sip front in the
long-term.
Tim, actually the generated python code now includes python DocStrings,
so it should be much easier to inspect an appropriate python
documentation directly with `help(QgsVectorLayer)` etc.
And to automatically generate an up-to-date python documentation.
Cheers
Matthias
On 03/30/2017 05:02 PM, Denis Rouzaud wrote:
> Le jeu. 30 mars 2017 à 16:56, Tim Sutton <tim at kartoza.com
> <mailto:tim at kartoza.com>> a écrit :
> Hi
>> On 30 Mar 2017, at 3:18 PM, Denis Rouzaud <denis.rouzaud at gmail.com
>> <mailto:denis.rouzaud at gmail.com>> wrote:
>> Dear all,
>> I'd like to raise the attention on a new workflow I just merged to
>> automatically generate SIP files using the header as source only.
>> A PR is pending for the documentation, but you can read it here
>> https://github.com/3nids/QGIS-Documentation/blob/6e3a9fb6f98a2869aef27c01b7ab70eb0a4c7556/source/docs/developers_guide/codingstandards.rst#sip-bindings
>> (waiting to be merged).
>> For the moment, only 3 files are generated (qgsattributes,
>> qgsfeature and qgsvectorlayer). One can starts adding new files to
>> the process by adapting their header and removing them from
>> python/auto_sip.blacklist.
> This is really great! A couple of questions:
> 1) the blacklist implies that any new .h files added to the source
> tree will automatically have sip bindings generated unless you
> explicitly blacklist them?
> As soon as you add the include in python/core/core.sip (or gui,
> analysis), the SIP is considered as automatically generated from header
> except if you blacklist it.
> 2) are you thinking to maintain the sip files in Git still or remove
> the from revision in favour of having them as build time artifacts
> only? I ask this because I often direct people to use the sip files
> as a reference guide for the python API if they want to dig under
> the hood a bit more.
> The goal is to remove the SIP files and have them created on build time.
> But:
> 1) I except a few errors in the script to arise (so better to have an
> easy access to the SIP files)
> 2) it needs to reach a significant point of ported headers.
> So, in a somehow close or far future, yes they'll be removed from source
> (hence no blacklist anymore only manual files such as core/conversions.sip).
> Qgis-developer mailing list
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
