[Qgis-developer] No module named
Neumann, Andreas a.neumann at carto.net
Wed May 3 01:01:05 PDT 2017
I am trying to get QGIS quickfinder running (the version from github,
not the packaged version), because I want to test the new Postgres
search functionality.
I checked out the source from https://github.com/3nids/quickfinder (the
master_2 version) and also the qsettingsmanager. I changed the Makefile
to reflect my Pythonpath. The make and make deploy went fine, but when I
load the plugin I get the error message
2017-05-03T09:55:09 1 Traceback (most recent call last):
File "C:/Program Files/OSGEO4~1/apps/qgis/./python\qgis\utils.py", line
333, in startPlugin
plugins[packageName] = package.classFactory(iface)
File "C:/Users/nend/.qgis2/python/plugins\quickfinder\__init__.py", line
28, in classFactory
from .quickfinder_plugin import QuickFinder
607, in _import
mod = _builtin_import(name, globals, locals, fromlist, level)
File
"C:/Users/nend/.qgis2/python/plugins\quickfinder\quickfinder_plugin.py",
line 36, in <module>
from gui.configuration_dialog import ConfigurationDialog
607, in _import
File
"C:/Users/nend/.qgis2/python/plugins\quickfinder\gui\configuration_dialog.py",
line 38, in <module>
from project_search_dialog import ProjectSearchDialog
607, in _import
File
"C:/Users/nend/.qgis2/python/plugins\quickfinder\gui\project_search_dialog.py",
line 29, in <module>
from ..ui.ui_projectsearch import Ui_ProjectSearch
607, in _import
File
"C:/Users/nend/.qgis2/python/plugins\quickfinder\ui\ui_projectsearch.py",
line 123, in <module>
from qgsfieldexpressionwidget import QgsFieldExpressionWidget
607, in _import
ImportError: No module named qgsfieldexpressionwidget
Is qgsfieldexpressionwidget a separate Python plugin or why is not
found?
Thank you for any hints,
Andreas
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170503/bed4cb06/attachment.html>
More information about the QGIS-Developer mailing list
