[QGIS-Developer] [Qgis-developer] Processing: gdal_calc generates Python.exe has stopped working on Windows
René-Luc Dhont
rldhont at gmail.com
Thu May 11 05:15:53 PDT 2017
Hi all,
Even Rouault has proposed a solution to fix the issue:
The issue can be more simply reproduced when just doing "from osgeo
import gdalnumeric" and exiting the Python console.
This doesn't look like a fundamental flow of GDAL on Windows, since when
using miniconda, or when building myself GDAL (with VS 2010 express, 64
bit), I don't have this issue.
For the record, my build recipee for the python bindings
* install Python 2.7.12 64bit
* pip install numpy ==> install numpy 1.11.2
* set DISTUTILS_USE_SDK=1
* set MSSdk=1
* cd gdal/swig/python
* python setup.py build
Do you think the QGIS package for Windows could be fixed with this ?
Thanks,
René-Luc D'Hont
Le 25/04/2017 à 14:23, Alexander Bruy a écrit :
> Hi René-Luc,
> I have also seen this issue several times, and for me it also happen
> not only wth gdal_calc but also with other Python-based GDAL tools.
> I did not reported it because I was unable to produce stable test case.
> 2017-04-25 11:05 GMT+03:00 René-Luc Dhont <rldhont at gmail.com>:
>> Hi Jürgen,
>> Thanks for your answer.
>> I wonder if other QGIS user on Windows has already tested the GDAL
>> calculator and have the same issue as the reporter and my customer.
>> About Osgeo4W, we have opened a tickets 4 years ago about PHP to help users
>> tested Lizmap and QGIS Server on windows, but we nerver have any reaction
>> https://trac.osgeo.org/osgeo4w/ticket/343
>> I know that QGIS is build with some packages coming from OSgeo4W, I suppose
>> that some part of the project are maintained and I thank you those who do
>> it.
>> Regards,
>> René-Luc
>> Le 24/04/2017 à 11:46, Jürgen E. Fischer a écrit :
>> Hi René-Luc,
>> On Mon, 24. Apr 2017 at 11:21:50 +0200, René-Luc Dhont wrote:
>> Does someone else has encountered this issue ?
>> The reporter.
>> Do you know if Osgeo4W is maintained ?
>> Depends how you define it.
>> Jürgen
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170511/38b064de/attachment-0001.html>
