[QGIS-Developer] multi-layered pdf, attribute support in pdf outputs
hilpers
orchestra-mur at web.de
Thu May 11 23:18:41 PDT 2017
Hello everyone,
i am wondering whether it is going to be possible to generate multi-layered
pdfs using print composer anytime soon. While GDAL supports that QGIS does
not seem to do so yet. For making maps available to the public it would be
practival to implement layer attributes within pdf (similarly to ArcGIS). Is
this technically possible using GDAL?
Thanks,
hilpers
View this message in context: http://osgeo-org.1560.x6.nabble.com/multi-layered-pdf-attribute-support-in-pdf-outputs-tp5320273.html
Sent from the QGIS - Developer mailing list archive at Nabble.com.
