[QGIS-Developer] Postgis loading using COPY instead of INSERTS?
Régis Haubourg
regis.haubourg at gmail.com
Mon May 15 02:23:04 PDT 2017
Hi all,
I realized that QGIS only loads datasets to Postgres using INSERT commands,
which is very slow for big tables, and could propose to use COPY commands
with a parameter to choose how many rows are sent in each bulk COPY
command. (see [0])
I tested drag and drop in browser and dbmanager (in 2.18.7 and master) and
couldn't find anything about that in the issues or the code base.
Did I miss something? Is there someone working in that area?
Thanks for your lights
Régis
[0] https://www.postgresql.org/docs/current/static/populate.html
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170515/9e69eeca/attachment.html>
