[QGIS-Developer] geocoders in processing
Alexander Bruy
alexander.bruy at gmail.com
Fri May 19 23:19:42 PDT 2017
Hi Richard,
I think this is possible. Processing already supports string and coordinates
as parameters, so it should be relatively easy to pass address represented
by string parameter and get a point vectro layer with location or pass
coordinates and return either string or vector layer with new column, containing
address.
2017-05-20 0:35 GMT+03:00 Richard Duivenvoorde <rdmailings at duif.net>:
> Hi List,
> /me wondering if geocoder-providers should/could be used in processing.
> Currently I cannot find an example, but it was earlier proposed by
> someone in my geocoder QEP, see [0]
> I'm hoping that QGIS could maybe come up with a reusable gui for using
> such processing geocoder providers....
> Any idea's of what kind of api/input/output to use for that?
> Regards,
> Richard
> [0] https://github.com/qgis/QGIS-Enhancement-Proposals/issues/64
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Alexander Bruy
