[QGIS-Developer] "Affected version" field on redmine
Giovanni Manghi giovanni.manghi at gmail.com
Tue May 23 03:23:38 PDT 2017
We really needed to simplify the form for fling the issue reports, so
basically in Essen at the last dev meeting
we also had to compromise. Is perfect? no,but as is now is much more
better than before.
> 4 months later the "Target Version" field value was removed
> by Jean-Gabriel JGH. Shortly after Giovanni set "Target Version"
> to "2.18" and changed "Affected Version" from "2.16.1" to "2.18.4",
> effectively loosing the information about the oldest known
> affected version.
the idea behind that type of changes is to make clear what is the
latest version affected by the bug.
If the bug effectively started affecting a previous this is usually
stated in the description or in a comment.
Target version is now gone, so don't even speak about it now, not many
were considering that at all.
More information about the QGIS-Developer mailing list
