[QGIS-Developer] OTB 6 and Processing
Victor Olaya
volayaf at gmail.com
Tue May 23 04:11:48 PDT 2017
To transfer the repo i need permission to create new repos under that
org. If you can give me rights to do it, I will do the transfer and
then you can revoke them
Thanks
2017-05-22 10:22 GMT+02:00 Rashad Kanavath <mohammedrashadkm at gmail.com>:
> You can transfer to orfeotoolbox. this is the official github account and
> all devs have access to it.
> https://github.com/orfeotoolbox
> On Wed, May 17, 2017 at 12:04 PM, Victor Olaya <volayaf at gmail.com> wrote:
>> I agree 100% on what Alex said.
>> Rashad, instead of adding your user, can I completely move the
>> ownership to you or to another account that is managed by the OTB
>> team?
>> 2017-05-17 11:18 GMT+02:00 Alexander Bruy <alexander.bruy at gmail.com>:
>> > Hi Rashad,
>> > 2017-05-16 11:46 GMT+03:00 Rashad Kanavath <mohammedrashadkm at gmail.com>:
>> >> okay. current version needs update of lot of xml files, change in
>> >> version
>> >> number, list of application inside the otb plugin sources. I want to
>> >> avoid
>> >> that. And I think both OTB and QGIS developers will agree on this.
>> >> instead of xml files, otb can directly output those csv files which are
>> >> read
>> >> by processing core.
>> > I'm not against this, but IMHO such work should go for 3.0, as it
>> > requires
>> > many changes in OTB provider. Pushing this changes in 2.18 is dangerous
>> > (we already have broken SAGA support because of too fast switch to
>> > SAGA 2.3.1) and may break OTB support in LTR version.
>> > I think OTB team should take ownership on OTB provider plugin (it is
>> > hosted
>> > in the Victor's repository now) and start impelement new functionality.
>> > For
>> > QGIS 2.18 better to leave OTB support as is, or maybe backport some
>> > fixes and description files to have OTB 5.4. and 5.6.
>> > Alexander Bruy
>> > _______________________________________________
>> > QGIS-Developer mailing list
>> > QGIS-Developer at lists.osgeo.org
>> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Regards,
> Rashad
