[QGIS-Developer] A Couple of Plugin Ideas
C Hamilton adenaculture at gmail.com
Thu May 25 12:53:20 PDT 2017
I have been toying with writing a couple of QGIS plugins and wanted to
check to see if anyone else is doing something similar and to see if there
is interest.
1. Geospatial Animator
What I am thinking of is a plugin where you can define a series key
locations keeping track of the (X,Y) coordinate and zoom level.
Additionally there would be a step size and it would output either rendered
frames or a video.
2. Another Measure Tool
As a preface I was looking at some old archaeological records and it was
giving site locations based off of the previous location with a distance
and bearing. As far as I can tell there is no tools that interactively
gives both of these values.
I would like a measure tool that provides the distance between points A &
B, the bearing from point A to B, and the bearing from point B to A.
I would appreciate any thoughts you have or whether someone is already
working on this.
Thanks,
Calvin
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170525/b4e2bca5/attachment.html>
More information about the QGIS-Developer mailing list
