[QGIS-Developer] QGIS3 QgsField : adding DATE / DATETIME / BLOB support
Mark Johnson mj10777 at googlemail.com
Sun May 28 20:55:08 PDT 2017
For QGIS3, adding support for other basic Field-Types in class
QgsField, such as DATE / DATETIME and BLOBs should be taken into
consideration.
Also adding a field (SQLITE stored as 'cid') which would represent the
Field number inside the TABLE could simplify the use inside a Provider.
At the moment only String / Int / Double are supported.
Mark Johnson
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170529/fb35ec1a/attachment.html>
More information about the QGIS-Developer mailing list
