[QGIS-Developer] QGIS3 QgsField : adding DATE / DATETIME / BLOB support
Mark Johnson mj10777 at googlemail.com
Sun May 28 21:25:35 PDT 2017
>> What makes you think that?
Based on the implementation of the QgsSpatiaLiteProvider (which only
supports TEXT, INTEGER and DOUBLE) and the documentation of QgsField.
>> Constructor. Constructs a new QgsField object.
     * \param type Field variant type, currently supported: String / Int /
Double
     * \param typeName Field type (e.g., char, varchar, text, int, serial,
double).
     * Field types are usually unique to the source and are stored exactly
     * as returned from the data store.
and the usage of type in displayString and convertCompatible.
Mark
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170529/d5d507b3/attachment.html>
More information about the QGIS-Developer mailing list
