[QGIS-Developer] Drag and drop to PostGIS crash
Radim Blazek radim.blazek at gmail.com
Tue May 30 00:55:49 PDT 2017
On Tue, May 30, 2017 at 9:40 AM, Sandro Santilli <strk at kbt.io> wrote:
> On Tue, May 30, 2017 at 04:39:01PM +1000, Nyall Dawson wrote:
>> On 30 May 2017 at 16:30, Radim Blazek <radim.blazek at gmail.com> wrote:
>> > Hi,
>> > QGIS3 crashes when a vector is dragged and drop to PostGIS in browser
>> > in qgspostgresconn.cpp on
>> >     // sharing connection between threads is not safe
>> >     // See https://issues.qgis.org/issues/13141
>> >     Q_ASSERT( QApplication::instance()->thread() == QThread::currentThread() );
>> > the issue mentioned above is about something different (loading items
>> > in thread) and it is marked as resolved.
>> Works OK here if I remove that assert... can you test and confirm that
>> it's safe to remove? I don't know the history here...
> IIRC that comment was mine, and was there because the PostgreSQL
> connection pooler was not thread safe so using it from different
> thread might cause hard-to-debug issues. If this is confirmed then
> the fact you see things working OK is not really reassuring.
> For some reason I think https://github.com/qgis/QGIS/pull/2690 was
> also meant to improve that weird shared connection handling by
> deprecating some methods.
Calling QgsPostgresConn::connectDb with shared=false should be OK, right?
Radim
More information about the QGIS-Developer mailing list
