[QGIS-Developer] New plugin version approval
Michel Stuyts
michel.stuyts at edegem.be
Mon Oct 2 04:47:58 PDT 2017
I wrote a local repo implementation in PHP a while ago, if you have a server with PHP you can use this simple script. You can find it on Github: https://github.com/mstuyts/phpQGISrepository
Michel
________________________________________
Van: QGIS-Developer [qgis-developer-bounces at lists.osgeo.org] namens Alex Zvoleff [azvoleff at conservation.org]
Verzonden: maandag 2 oktober 2017 11:25
Aan: Tom Chadwin; qgis-developer at lists.osgeo.org
Onderwerp: Re: [QGIS-Developer] New plugin version approval
Thanks Tim, Tom and others. I hadn't considered the option of our own repo. I will keep this in mind. Thanks!
Best,
Alex
> -----Original Message-----
> From: QGIS-Developer [mailto:qgis-developer-bounces at lists.osgeo.org] On
> Behalf Of Tom Chadwin
> Sent: Sunday, October 01, 2017 9:56 PM
> To: qgis-developer at lists.osgeo.org
> Subject: Re: [QGIS-Developer] New plugin version approval
> Hi Alex
> Have you considered setting up your own plugin repo? I think you need some
> hosting and an XML file - hopefully fairly easy to set up.
> Tom
> Buy Pie Spy: Adventures in British pastry 2010-11 on Amazon
> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-
> f4099106.html
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
