[QGIS-Developer] Geopackage: ERROR: Too many connections: max 64 ?
Richard Duivenvoorde
rdmailings at duif.net
Mon Oct 2 07:55:46 PDT 2017
Hi Devs,
I created a geopackage from 144 individual (hourly data) shapefiles as
individual tables (in one gpkg).
To load all those tables in QGIS I can 'load vector data', point to the
gpkg, choose 'select all' and then OK.
BUT: it looks like both in 2.18 and in master it for every table QGIS
(or OGR?) creates a connection?
In my Debug builds the loading takes several minutes showing me msg
like:
src/providers/ogr/qgsogrprovider.cpp: 3196: (OGRDestroyWrapper) [167ms]
GPKG: Trying to return to delete mode
src/providers/ogr/qgsogrprovider.cpp: 3214: (OGRDestroyWrapper) [0ms]
Return: In ExecuteSQL(): sqlite3_step(PRAGMA journal_mode = delete):
database is locked
src/providers/ogr/qgsogrprovider.cpp: 3224: (OGRDestroyWrapper) [3ms]
GPKG: Trying again
And when I close the project or try to create a new project this happens
again:
src/providers/ogr/qgsogrprovider.cpp: 3224: (OGRDestroyWrapper) [4ms]
GPKG: Trying again
src/providers/ogr/qgsogrprovider.cpp: 3242: (OGRDestroyWrapper) [163ms]
Return: wal
src/providers/ogr/qgsogrprovider.cpp: 3196: (OGRDestroyWrapper) [5ms]
src/providers/ogr/qgsogrprovider.cpp: 3214: (OGRDestroyWrapper) [1ms]
database is locked
In general both processes will finally end, but I think this is/will be
a problem in the future?
Note that loading the 144 shapefiles take a lot less time.
I'm not sure if I'm stretching the usability of GeoPackage too much
here?
(my plan is/was to create a grouplayer-player, a group(p)layer: some
buttons for given layergroup to show/hide the next layer thereby having
a poor-man's 'time'-manager...
Is it possible (at least for the loading of several tables at once) to
do the opening/closin sequential over the same connections.
Or should we 'just' make 'max 64' 'max 6400' ;-)
Is there a solution thinkable for this, should I create an issue?
Regards,
PS: Happy to provide the (1.1 Gb) Geopackage I created for testing.
(note that the 144 shapefile were also almost 1Gb, BUT zipped it is
about 250Mb).
PS2: Also trying to discuss this in the light of the future of gpkg in
QGIS.
