[QGIS-Developer] Qt Model-View updates blocked when Python console not open
Matthias Kuhn matthias at opengis.ch
Thu Oct 5 07:18:06 PDT 2017
Hi Peter,
Have a look at this answer here, which explains how you can trigger the
same behavior without using the print and relying on side-effects of the
console open.
It also outlines the risks involved in using this kind of approach.
https://gis.stackexchange.com/a/257016
Cheers
Matthias
On 10/05/2017 03:25 PM, Peter Devoy wrote:
> Just a little update; it is the fact I am using print() to output
> debug information upon each request which is allowing the UI to
> repaint.  Also, it seems that opening and closing the Python console
> once is enough.
> Peter
> 3XE
> P: 01326 567155
> M: 07770 693662
> A: 3XE Ltd
> Tremough Innovation Centre
> PENRYN
> TR10 9TA
> 3XE Ltd · Registered in England and Wales · 9356871
> On 4 October 2017 at 20:53, Peter Devoy <peter at 3xe.co.uk> wrote:
>> Hi all
>> In my plugin I have extended QAbstractListModel to create a list of
>> objects; each object in the list has a 'url' property containing the
>> URL of an API resource.  When the user selects a feature in main QGIS
>> interface, each object in the list makes a HTTP request to its URL and
>> updates its properties from the response data.
>> Changes in the objects' properties are reflected in a QListView.  E.g.
>> a  property 'status'  is set to 'WARN' if the HTTP request fails --
>> this is reflected in the QListView by the respective list item's icon
>> turning yellow.
>> If I have the Python console open in QGIS the QListView items update
>> as the ListModel's objects update. However, if the Python console is
>> not open, the plugin's UI thread appears to be blocked until each item
>> in the list has completed its changes and all the items update at
>> once; please can anyone recommend a way to avoid this?
>> I have been developing on QGIS 2.1X.
>> Kind regards
>> Peter
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
