[QGIS-Developer] QGIS master branch fails make install on macOS 10.12.6
David Marteau
dmarteau at 3liz.com
Fri Oct 6 04:59:30 PDT 2017
Hi
Try to define the environment variable QT_QPA_PLATFORM_PLUGIN_PATH=/opt/local/libexec/qt5/plugins/platforms (it may depends on how is your qt5 installation - this path is ok for Macport installation)
According to my experience (see https://www.3liz.com/blog/rldhont/index.php?post/2017/06/01/How-to-build-qgis-on-OSX-with-MacPort) : If this variable is not defined then QGIS will crash at startup.
> Le 6 oct. 2017 à 09:46, Joel Buckley <qgis at spam.joelbuckley.com.au> a écrit :
> Hi,
> I am having some difficulty running `make install`, and compiling QGIS into a single standalone application on macOS. I can successfully run configuration and `make`, and can launch the `make`-d code from build/output/bin with no problem.
> `make install` runs without complaint and returns 0 (success), but when I try to launch the newly create QGIS.app, it immediately crashes, and produces a crash report (attached for brevity).
> I have googled and attempted to parse the crash log, but the errors it reports are beyond my capability. I'm hoping someone on the list might have some input on how to remedy this?
> Configuration information:
> QGIS version: current master branch
> QT5, python 3
> macOS 10.12.6
> Regards,
> Joel Buckley
> <crash.txt>_______________________________________________
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171006/3e397def/attachment.html>
