[QGIS-Developer] Custom CRS broken in master?
Matthias Kuhn matthias at opengis.ch
Sat Oct 7 05:40:20 PDT 2017
Hi Anita,
Just reading through the tickets and without much context: they very
much look like individual issues without any overlap, so I would go for
different tickets.
Thanks
Matthias
On 10/07/2017 02:07 PM, Anita Graser wrote:
> I've now tested this on another machine and the issues are same.
> I open separate tickets or one with all three issues?
> Regards,
> Anita
> On Fri, Oct 6, 2017 at 7:46 PM, Anita Graser <anitagraser at gmx.at
> <mailto:anitagraser at gmx.at>> wrote:
>     Hi,
>     I'm experiencing a couple of issues related to custom / generated
>     CRS in master (tested using OSGeo4W):
>     1. In Processing: If the input layer uses a generated / custom
>     CRS, the output layer is loaded in a wrong CRS. In my case, the
>     layers were wrongly assigned WGS84. (Note that, in settings, I've
>     configured that QGIS should "prompt for CRS" if a layer without
>     CRS info is loaded.) --> Reported
>     https://issues.qgis.org/issues/17254
>     <https://issues.qgis.org/issues/17254>
>     2. I have a project with a custom CRS used as the project CRS. It
>     was created with 2.14. When I open it in master, a different CRS
>     is assigned. Could be the one with the same random generated ID
>     that custom CRS get.
>     3. The Custom CRS Definition dialog is a mess. Most of the time, I
>     cannot make it save the new CRS I'm trying to add. At the same
>     time, existing entries are duplicated on opening & closing the dialog.
>     Anyone else having these issues? Or is my local install just
>     really broken?
>     Regards
>     Anita
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171007/252f558d/attachment.html>
More information about the QGIS-Developer mailing list
