[QGIS-Developer] QGIS master build on Ubuntu 16.04 with python support
Jorge Gustavo Rocha
jgr at di.uminho.pt
Mon Oct 9 06:32:31 PDT 2017
Hi Theuns,
Can you check which python/QT5 modules you have installed?
In my Ubuntu 16.04:
jgr at dusseldorf:~$ dpkg -l | grep pyqt5 | awk '{print $2}'
pyqt5-dev
pyqt5-dev-tools
pyqt5.qsci-dev
python-pyqt5
python-pyqt5.qtsvg
python-pyqt5.qtwebkit
python3-pyqt5
python3-pyqt5.qsci
python3-pyqt5.qtsql
python3-pyqt5.qtsvg
Regards,
Jorge
On 09-10-2017 14:12, Theuns Heydenrych wrote:
> Hi
> I am building QGIS master on Ubuntu 16.04 with python support and the
> build fails at 99%
> This is the error message I get.
> /[ 99%] Generating ui_DlgVersioning.py/
> /cd
> /home/dev/code/build-QGIS-Desktop_Qt_5_5_1_GCC_64bit-Debug-Python/python/plugins/db_manager/db_plugins/postgis/plugins/versioning
> && /home/dev/code/QGIS/scripts/pyuic-wrapper.sh /usr/bin/pyuic5
> /home/dev/code/build-QGIS-Desktop_Qt_5_5_1_GCC_64bit-Debug-Python/output/lib
> /home/dev/code/build-QGIS-Desktop_Qt_5_5_1_GCC_64bit-Debug-Python/output/python
> /usr/bin/python3
> /home/dev/code/QGIS/python/plugins/db_manager/db_plugins/postgis/plugins/versioning/DlgVersioning.ui
> -o
> /home/dev/code/build-QGIS-Desktop_Qt_5_5_1_GCC_64bit-Debug-Python/python/plugins/db_manager/db_plugins/postgis/plugins/versioning/ui_DlgVersioning.py/
> /Traceback (most recent call last):/
> / File "/home/dev/code/QGIS/scripts/pyuic-wrapper.py", line 26, in
> <module>/
> / import qgis.PyQt.uic.pyuic/
> / File
> "/home/dev/code/build-QGIS-Desktop_Qt_5_5_1_GCC_64bit-Debug-Python/output/python/qgis/__init__.py",
> line 72, in <module>/
> / from qgis.core import QgsFeature, QgsGeometry/
> / File
> "/home/dev/code/build-QGIS-Desktop_Qt_5_5_1_GCC_64bit-Debug-Python/output/python/qgis/core/__init__.py",
> line 34, in <module>/
> / from qgis._core import */
> /ImportError: /usr/lib/x86_64-linux-gnu/libQt5Gui.so.5: undefined
> symbol: _Z10qAllocMoreii/
> /python/plugins/db_manager/db_plugins/postgis/plugins/versioning/CMakeFiles/zzz-db_manager-5-depend.dir/build.make:62:
> recipe for target
> 'python/plugins/db_manager/db_plugins/postgis/plugins/versioning/ui_DlgVersioning.py'
> failed/
> /make[2]: ***
> [python/plugins/db_manager/db_plugins/postgis/plugins/versioning/ui_DlgVersioning.py]
> Error 1/
> /make[2]: Leaving directory
> '/home/dev/code/build-QGIS-Desktop_Qt_5_5_1_GCC_64bit-Debug-Python'/
> /CMakeFiles/Makefile2:3920: recipe for target
> 'python/plugins/db_manager/db_plugins/postgis/plugins/versioning/CMakeFiles/zzz-db_manager-5-depend.dir/all'
> failed/
> /make[1]: ***
> [python/plugins/db_manager/db_plugins/postgis/plugins/versioning/CMakeFiles/zzz-db_manager-5-depend.dir/all]
> Error 2/
> /make[1]: Leaving directory
> /Makefile:149: recipe for target 'all' failed/
> /make: *** [all] Error 2/
> Seems like ImportError: /usr/lib/x86_64-linux-gnu/libQt5Gui.so.5:
> undefined symbol: _Z10qAllocMoreii is the issue.
> I have checked with:
> /nm -D /usr/lib/x86_64-linux-gnu/libQt5Gui.so.5 | grep _Z10qAllocMoreii/
> and the out put is:
> / U _Z10qAllocMoreii/
> Which show it is undefined. If I
> check /usr/lib/x86_64-linux-gnu/libQt5Core.so.5 I can see that the
> function id defined.
> /nm -D /usr/lib/x86_64-linux-gnu/libQt5Core.so.5 | grep
> _Z10qAllocMoreii/ and the output is:
> /00000000000a8c80 T _Z10qAllocMoreii/
> So I dont know exactly how to fix this, it seems like the
> /usr/lib/x86_64-linux-gnu/libQt5Core.so.5 should be visible to the
> complier or python at this build step?
> Any thoughts how to handle this?
> Regards
> Theuns Heydenrych
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
J. Gustavo
Jorge Gustavo Rocha
Departamento de Informática
Universidade do Minho
4710-057 Braga
Tel: +351 253604480
Fax: +351 253604471
Móvel: +351 910333888
skype: nabocudnosor
