[QGIS-Developer] Qt Model-View updates blocked when Python console not open
Peter Devoy
peter at 3xe.co.uk
Wed Oct 11 10:08:52 PDT 2017
Hi guys
Thank you all for your suggestions. Calls to print() triggering
QCoreAppliation::processEvents() explains the phenomena and I was able
to fix using the Boundless's QNetworkAccessManager wrapper instead of
the requests library.
Thanks again!
Peter
On 6 October 2017 at 07:41, Richard Duivenvoorde <rdmailings at duif.net> wrote:
> And to make things easier, use
> https://github.com/boundlessgeo/lib-qgis-commons/blob/master/qgiscommons2/network/networkaccessmanager.py
> which should be core class in QGIS if you ask me. So we can get rid of
> all other different blocking/nonproxying etc ways to connect QGIS to http...
> Regards,
> On 05-10-17 22:01, Ricardo Filipe Soares Garcia da wrote:
> > Hi Peter
> > In addition to Matthias' advice perhaps try using
> > QNetworkAccessManager[1] and related classes in order to deal with your
> > http requests asynchronously. This should fix the UI blocking issues.
> > Best regards
> > [1]
> > - http://pyqt.sourceforge.net/Docs/PyQt4/qnetworkaccessmanager.html#details
> > Em 05/10/2017 15:18, "Matthias Kuhn" <matthias at opengis.ch
> > <mailto:matthias at opengis.ch>> escreveu:
> > Hi Peter,
> > Have a look at this answer here, which explains how you can trigger
> > the same behavior without using the print and relying on
> > side-effects of the console open.
> > It also outlines the risks involved in using this kind of approach.
> > https://gis.stackexchange.com/a/257016
> > <https://gis.stackexchange.com/a/257016>
> > Cheers
> > Matthias
> > On 10/05/2017 03:25 PM, Peter Devoy wrote:
> > Just a little update; it is the fact I am using print() to output
> > debug information upon each request which is allowing the UI to
> > repaint. Also, it seems that opening and closing the Python console
> > once is enough.
> > Peter
> > 3XE
> > P: 01326 567155
> > M: 07770 693662
> > A: 3XE Ltd
> > Tremough Innovation Centre
> > PENRYN
> > TR10 9TA
> > 3XE Ltd · Registered in England and Wales · 9356871
> > On 4 October 2017 at 20:53, Peter Devoy <peter at 3xe.co.uk
> > <mailto:peter at 3xe.co.uk>> wrote:
> > Hi all
> > In my plugin I have extended QAbstractListModel to create a
> > list of
> > objects; each object in the list has a 'url' property
> > containing the
> > URL of an API resource. When the user selects a feature in
> > main QGIS
> > interface, each object in the list makes a HTTP request to
> > its URL and
> > updates its properties from the response data.
> > Changes in the objects' properties are reflected in a
> > QListView. E.g.
> > a property 'status' is set to 'WARN' if the HTTP request
> > fails --
> > this is reflected in the QListView by the respective list
> > item's icon
> > turning yellow.
> > If I have the Python console open in QGIS the QListView
> > items update
> > as the ListModel's objects update. However, if the Python
> > console is
> > not open, the plugin's UI thread appears to be blocked until
> > each item
> > in the list has completed its changes and all the items
> > update at
> > once; please can anyone recommend a way to avoid this?
> > I have been developing on QGIS 2.1X.
> > Kind regards
> > Peter
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> > <mailto:QGIS-Developer at lists.osgeo.org>
> > List info:
> > https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
> > Unsubscribe:
> > QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
