[QGIS-Developer] Is PySpatiaLite needed for QGIS v3?
Matthias Kuhn
matthias at opengis.ch
Tue Oct 24 00:17:37 PDT 2017
On 10/24/2017 08:59 AM, a.furieri at lqt.it wrote:
> On Mon, 23 Oct 2017 17:02:27 -0500, Germán Carrillo wrote:
> most common pitfalls emerging from several post on the spatialite's
> own mailing list:
> - badly mixing 32 and 64 bit code: Python 32 bit strictly requires
> 32 bit extension modules, exactly as Python 64 bit requires
> 64 bit extensions.
> - mod_spatialite depends on several further libraries: libgeos,
> libproj, libxml2 etc. if just one of these dependencies remains
> unsatisfied loading mod_spatialite will consequently fail.
> - a badly set %PATH% (or badly installed dependencies) always is
> the most probable failure cause.
IIRC there was also the requirement that a compile-time-switch
SQLITE_ENABLE_LOAD_EXTENSION needs to be set which unfortunately isn't
enabled by default on some builds (but I cannot recall the details).
Matthias
> bye Sandro
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
