[QGIS-Developer] building project zzz-db_manager-15-depend.vcxproj - FAILED
nihcas nihcas.c76 at gmail.com
Mon Oct 30 20:13:45 PDT 2017
I am try to build qgis master in windows 10 with visual studio 2017 with
RelwithDebInfo and getting error while building zzz-db_manager-15-depend.
3>------ Build started: Project: zzz-db_manager-15-depend, Configuration:
RelWithDebInfo x64 ------
3>Building Custom Rule
D:/qgis-master-source/python/plugins/db_manager/CMakeLists.txt
3>CMake does not need to re-run because
D:/Qgis-master-build/try1/python/plugins/db_manager/CMakeFiles/generate.stamp
is up-to-date.
3>Generating ui_DlgAddGeometryColumn.py
3>Traceback (most recent call last):
3>  File "D:\qgis-master-source\scripts\\pyuic-wrapper.py", line 26, in
<module>
3>    import qgis.PyQt.uic.pyuic
3>  File "D:\Qgis-master-build\try1\output\python\qgis\__init__.py", line
72, in <module>
3>    from qgis.core import QgsFeature, QgsGeometry
3>  File "D:\Qgis-master-build\try1\output\python\qgis\core\__init__.py",
line 34, in <module>
3>    from qgis._core import *
3>ImportError: DLL load failed: The specified module could not be found.
3>C:\Program Files (x86)\Microsoft Visual
Studio\2017\Community\Common7\IDE\VC\VCTargets\Microsoft.CppCommon.targets(171,5):
error MSB6006: "cmd.exe" exited with code 1.
3>Done building project "zzz-db_manager-15-depend.vcxproj" -- FAILED.
========== Build: 2 succeeded, 1 failed, 10 up-to-date, 0 skipped ==========
Can any one help out this.
Regards
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
More information about the QGIS-Developer mailing list
