[QGIS-Developer] Crash launching Qgis 2.99.0
Adam Tokelove
AdamT at sigmaconsult.co.nz
Tue Oct 31 20:32:57 PDT 2017
Hi
I think I have the same problem, on Antergos (arch) with qgis-2.99 from the aur nightly build (qgis-git).
I updated on Friday, and have had the problem since then. I've updated a couple of times since (most recently about an hour ago with aur/qgis-git 2.99.0.r42636.ac7e041a4c-1) to see if that solved it, but not so much.
The program opens fine, I can open a project, but as soon as the project layers have finished opening, it aborts with:
QGIS died on signal 11Aborted (core dumped)
Cheers
Adam Tokelove
>Looks like an issue with some python code.
>Try starting without any plugins.
>Matthias
Hi Matthias,
I tried to launch qgis with --noplugins but I had:
https://paste.ubuntu.com/25852320/
which points more or less the same issues of before.
Other hints?
E.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171101/b4bcc828/attachment.html>
