[QGIS-Developer] OGR: sqlite with subset query, QgsOgrFeatureIterator::fetchFeature with SpatialFilterRect always returns feature with id 0
Sandro Mani
manisandro at gmail.com
Sat Sep 2 14:27:32 PDT 2017
Hi Even
On 02.09.2017 21:49, Even Rouault wrote:
> There's a flow in your reproducer. You run OGR_DS_ExecuteSQL( ds,
> subsetQuery, NULL, NULL ); but do not use the resulting result layer.
> So basically this has no effect on the rest of your code (except a
> memory leak).
Ah yes indeed!
> The reason is that when issuing a SQL request there's no guarantee
> that it will result in a set of rows with unique identifiers (think of
> a join that could make several rows appear twice), so the FID on the
> result set of ExecuteSQL() are just a sequence starting at 0.
Ok makes sense. Though as far as QGIS goes, is there a case where a
subset query can result in duplicates?
> If you know that your request will result in a result set with real
> FIDs you can use the following trick to get the FID column as a
> regular column (renaming the ogc_fid as something else, since there's
> special logic to ignre "ogc_fid as a regular field. If your FID field
> name is already something else than this default "ogc_fid", then
> you'll already get it as a regular field)
> $ ogrinfo poly.sqlite -sql "select ogc_fid as this_is_the_fid, * from
> poly where ogc_fid = 10"
> INFO: Open of `poly.sqlite'
> using driver `SQLite' successful.
> Layer name: SELECT
> Geometry: Unknown (any)
> Geometry Column = GEOMETRY
> this_is_the_fid: Integer (0.0)
> area: Real (0.0)
> eas_id: Integer64 (0.0)
> prfedea: String (0.0)
> OGRFeature(SELECT):0
> this_is_the_fid (Integer) = 10
> area (Real) = 5268.813
> eas_id (Integer64) = 170
> prfedea (String) = 35043413
> POLYGON ((479750.6875 4764702.0,479658.59375 4764670.0,479640.09375
> 4764721.0,479735.90625 4764752.0,479750.6875 4764702.0))
Something like this [1] seems to fix the issue, don't know if it's the
best way forward though?
Thanks
Sandro
[1]
https://github.com/manisandro/QGIS/commit/e95eea6dfa3e7ce7d0c0796352fa39943be80031
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170902/5b46a302/attachment-0001.html>
