[QGIS-Developer] What to do with QgsTransectSample for 3.0?
Nyall Dawson
nyall.dawson at gmail.com
Sun Sep 3 16:10:42 PDT 2017
On 28 August 2017 at 21:32, Victor Olaya <volayaf at gmail.com> wrote:
> I would advice to go with 1
> It's not likely anyone will use this class, so it's the safest option, IMHO
PR here: https://github.com/qgis/QGIS/pull/5116
Nyall
> 2017-08-26 15:15 GMT+02:00 Nyall Dawson <nyall.dawson at gmail.com>:
>> Hi all,
>> I've just been doing some cleanups on the analysis lib - see
>> https://github.com/qgis/QGIS/pull/5078, and I'm now wondering what we
>> should do with the QgsTransectSample class.
>> Earlier in the cycle Alex and Victor did a bunch of work exposing a
>> lot of the analysis lib functionality via processing. But this class
>> is not used anywhere - it's not utilised by the master c++ code, and
>> is not exposed via processing either. So we're carrying it around only
>> for potential use by 3rd party plugins/scripts.
>> BUT:
>> - it's unmaintained, and has had no work done (beside compilation
>> fixes) in the recent past
>> - it's outdated, and has a bunch of antique assumptions (like always
>> writing to shapefile outputs)
>> - there's 0 unit tests
>> - there's almost no documentation on exactly WHAT this class does, and
>> how it should be correctly used. And without use in the master
>> codebase to model from, I can't see how a 3rd party can be expected to
>> utilise this code correctly anyway.
>> Options I see are:
>> 1. remove it and avoid the issues
>> 2. get someone who knows how transect sampling SHOULD work to look
>> over the current logic, take up maintenance, add unit tests, and
>> expose this functionality via processing
>> 3. leave it in it's current form with unknown quality and unexposed
>> functionality
>> Thoughts? I personally see 3 as not an option, and while 2 would be
>> nice, I honestly can't see anyone picking this up.
>> Nyall
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
