[QGIS-Developer] Shapefile corruption issue affecting GDAL >= 2.1.3 and GDAL >= 2.2.0
Even Rouault
even.rouault at spatialys.com
Thu Sep 7 04:54:50 PDT 2017
I want to notify those using OGR to do edition of shapefiles (modifications of
existing shape / SetFeature() + creation of new shape / CreateFeature()) that a
bug was found in a particular scenario: if you edit the last shape of the file to be
larger than its previous version (addition of a new vertex of a line/polygon), and
then add a new shape (in the same editing session), the previously last shape will
be corruped (the new last shape will start in the middle of it), and likely new
added shapes in the same editing session will corrupt their previous shape.
See https://trac.osgeo.org/gdal/ticket/7031 for details and patch
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170907/2444fbd0/attachment.html>
