[QGIS-Developer] processing runalg in code (not in console) problem
Stefano Masera stefano.masera at arpa.piemonte.it
Mon Sep 11 07:42:31 PDT 2017
Hi list,
I have a plugin that generate a shape in a temp directory using processing in the code (not in console).
After using it, at the end of the plugin I try to delete the temp directory, but I get an error because the directory is used by another process.
This is the step by step:
- open plugin
- create a temp directory
- create a shape in the temp directory with processing, code: processing.runalg(...)
- use the shape
- try to delete the temp directory (with the shape inside) and I have an access error.
I suppose the processing algorithm didn't close the file...
I know I can try by using memory layer, but actually I didn't wan't to use this solution.
What can I do?
Thanks
Stefano
Stefano Masera
Arpa Piemonte
Via Pio VII, 9 - 10135 Torino
www.arpa.piemonte.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170911/8c2ba5a1/attachment.html>
More information about the QGIS-Developer mailing list
