[QGIS-Developer] FeatureIterator Python question
Matthias Kuhn
matthias at opengis.ch
Fri Sep 15 07:22:26 PDT 2017
Hi Andreas,
that will be done automatically when the iterator scopes out or the last
feature is yielded.
There is normally no reason to care about this method.
Matthias
On 09/15/2017 04:04 PM, Andreas Neumann wrote:
> Just a quick followup question.
> I see that the QgsFeatureIterator has a close method.
> Should Python authors care about closing an existing feature iterator or
> would this be automatically done when the script stops executing?
> Andreas
> On 15.09.2017 15:48, Andreas Neumann wrote:
>> Hi Matteo and Matthias,
>> Thanks - that works fine. I did not know that this changed in Python 3.
>> All the poor QGIS book authors who need to rewrite their books ...
>> about this Python changes.
>> Helps a lot!
>> Andreas
>> On 15.09.2017 15:44, matteo wrote:
>>> Hi Andreas,
>>> if I'm not wrong the next method is not been removed, it is a python
>>> 3 *fix*
>>> https://stackoverflow.com/questions/1073396/is-generator-next-visible-in-python-3-0
>>> so instead of:
>>> it = layer.getFeatures()
>>> it.next()
>>> just type
>>> next(it)
>>> Matteo
>>> QGIS-Developer mailing list
>>> QGIS-Developer at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
