[QGIS-Developer] [WIP] GRASS Processing port to new API
Médéric Ribreux
mederic.ribreux at medspx.fr
Sat Sep 16 00:35:24 PDT 2017
Hello devs,
just a simple mail to tell you that I am currently working on QGIS3
Processing port of GRASS plugin.
You can read the code in my forked QGIS git repository:
https://github.com/medspx/QGIS/tree/ProcessingPortGrass72
For the moment, about 50% of the job is done:
- I have used the new QgsProcessing framework for parameters (I have
used modifications of processing/parameters.py made by Nyall in the SAGA
port).
- I have modified description files according to this new framework.
- I can launch most of the algorithms for rasters and vectors (and some
imagery).
- I have also worked on improving layers management (importing/exporting
into/from temporary GRASS DB).
I still need to work on the following points:
- Adapt and factorize ext/ scripts to the new framework.
- Multiformat support for vector and rasters.
- A better support for OutputFiles (HTML and text files).
- Add new GRASS7.2 algorithms (less than a dozen).
- Verify all description files to support the new parameters introduced
into GRASS7.2.
- Port and improve unit tests.
- Try to fix all bugs linked to unicode support under MS-Windows.
I am going offline for the next 3 weeks and I think I'll be able to make
a (decent) PR at the end of this period of time.
I really hope that QGIS3 will have GRASS Processing in its first
release...
Cheers!
Médéric RIBREUX
https://medspx.fr
