[QGIS-Developer] Warning - possible project corruption in 2.18.13
Nyall Dawson nyall.dawson at gmail.com
Tue Sep 19 23:45:47 PDT 2017
On 20 September 2017 at 10:18, Nyall Dawson <nyall.dawson at gmail.com> wrote:
> Hi all,
> I've just been trying to diagnose an issue with loading an existing
> 2.18 project in the new 2.18.13 release.
> Seems like something may be broken here with regards to loading OGR
> based layers which have a subset filter set.
> These layers trigger the "missing layers" dialog when loading the
> project and the layer link cannot be repaired without removing the
> filter clause.
> (specifically this is with .gdb layers on Windows - not sure yet if
> it's restricted to this combination).
> So just a heads up to test your existing projects before rolling out
> the 2.18.13 update.
Failing unit test is here: https://github.com/qgis/QGIS/pull/5222,
regression bisected to https://github.com/qgis/QGIS/commit/8eaeaaa
Sandro can you take a look at this?
Nyall
More information about the QGIS-Developer mailing list
