[QGIS-Developer] Refactor fields processing algorithm and expressions
Andreas Neumann a.neumann at carto.net
Wed Sep 20 05:29:54 PDT 2017
I am running into troubles using expressions in the "Refactor fields"
processing provider.
E.g. I have a date field and would like to reformat it in german format:
format_date("erfassungsdatum",'dd.MM.yyyy')
Although I am 100% certain that the above expression is syntactically
correct, the expression builder insists that the expression is invalid
and I can therefore not apply and save this expression.
Is this a known limitation because the model does not know which layer
it is tied to?
Are there any workarounds?
Thanks,
Andreas
More information about the QGIS-Developer mailing list
