[QGIS-Developer] QGIS/OGR: FeatureIds reassigned on write to data provider?
Sandro Mani
manisandro at gmail.com
Wed Sep 20 09:11:19 PDT 2017
On 20.09.2017 17:39, Even Rouault wrote:
> On mercredi 20 septembre 2017 17:32:27 CEST Sandro Mani wrote:
> > On 19.09.2017 19:15, Even Rouault wrote:
> > > On mardi 19 septembre 2017 18:30:50 CEST Sandro Mani wrote:
> > > > On 11.07.2017 14:31, Even Rouault wrote:
> > > > > We could potentially imagine to defer the repacking at
> > > > > leaveUpdateMode() time, actually in the close() method which
> is called
> > > > > when the reference counter of the update mode drops to zero (*),
> > > > > instead of doing it at the end of each operation.
> > > > To come back to this, I was looking at moving replack() to
> close(), but
> > > > noticed that syncToDisc() has the logic "for shapefiles, remove
> spatial
> > > > index files and create a new index" which calls close. And
> syncToDisk is
> > > > still called after every change. So should syncToDisk be also
> moved to
> > > > close(), or at least blocked if an updateMode is active?
> > > Yes that would probably make sense to block syncToDisk() while in
> > > updateMode (so when mUpdateModeStackDepth > 0), but probably only if
> > > enterUpdateMode() is called by QgsVectorLayer::startEditing(), and not
> > > when called implicitly by doInitialActionsForEdition(), which might be
> > > the case if someone directly works at the provider level
> > > bool QgsOgrProvider::doInitialActionsForEdition()
> > > if ( !mValid )
> > > return false;
> > > if ( !mWriteAccess && mWriteAccessPossible && mDynamicWriteAccess )
> > > QgsDebugMsg( "Enter update mode implictly" );
> > > if ( !enterUpdateMode() )
> > > return false;
> > > return true;
> > > So probably a mImplicitUpdateMode flag should be set above near the
> > > QgsDebugMsg(), and the check to decide whether we can defer
> > > syncToDisk() would be ( !mImplicitUpdateMode &&
> > Hm but will that flag never be cleared again once set? Since AFAICT a
> > there is no leaveUpdateMode matching the enterUpdateMode called by
> > doInitialActionsForEdition.
> > As I understand, the approach to do changes with stable ids would be to
> > first enterUpdateMode, then perform the changes, then leaveUpdateMode,
> > at which point the changes are synced and the dataset repacked.
> Yes
> > With the
> > mImplicitUpdateMode flag, if anyone worked directly at provider level
> > before you come along, deferring syncToDisk would never happen since the
> > mImplicitUpdateMode was set and remains set.
> Yes my idea was to keep the current behaviour where repack() is done
> frequently, as you cannot know when the dataset should be in a
> consistant state.
> But we could also decide to defer syncToDisk() at provider deletion
> (would make the code simpler)
> I have no idea of the existing use cases behind and if that would
> break some.
Suppose something like [1] should both allow reliably deferring
syncToDisk when an updateMode was explicitly entered while keeping the
current behaviour of immediate syncToDisk for implicit update mode.
Sandro
[1]
https://github.com/manisandro/QGIS/commit/13f451bdcbb653e9d69e55c79a5ba520d3f1712e
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170920/0279c8d4/attachment.html>
