[QGIS-Developer] Label Text Type case option 'Capitatlize first letter' ONLY capitalizes first letter
Tom Chadwin tom.chadwin at nnpa.org.uk
Fri Sep 22 02:29:28 PDT 2017
Hi Richard
If you are raising this for yourself, I'm sure you know this, but you can
achieve what you need with the expressions function "title()". I can also
see occasions when first-letter could be of use.
If your point is for other users, then there is certainly an argument for
including title case in that formatting dropdown.
Thanks
Tom
Buy Pie Spy: Adventures in British pastry 2010-11 on Amazon
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
More information about the QGIS-Developer mailing list
