[QGIS-Developer] [Qgis-psc] QGIS Grant: Expand unit test coverage for geometry classes
Andreas Neumann
a.neumann at carto.net
Tue Sep 26 04:38:47 PDT 2017
Hi Nyall,
This is much appreciated. Thanks so much for your continuous work and
effort to increase the quality of QGIS!
Andreas
On 2017-09-26 04:31, Nyall Dawson wrote:
> Hi PSC,
> Just reporting in that with PR #5254 [1 [1]], the grant work has now been
> completed and we're sitting as close as possible to 100% unit test
> coverage for the geometry primitive classes (i.e. the classes which
> represent the raw geometry types, such as points/multipoints/circular
> strings/ etc).
> While the purpose of this work wasn't directly to fix bugs, writing
> the tests has allowed me to identify and fix dozens of issues in these
> geometry classes. The fixes range from pedantic (e.g. crashes when
> requesting parts of the geometry with invalid indexes such as negative
> numbers), through to severe (a geometry corruption caused after
> converting a MultiLineString to GML which would definitely cause QGIS
> server to crash on certain requests).
> Just to ensure that there's no misconceptions here: having 100% test
> coverage doesn't mean the geometry classes are now bug free - rather
> it means that the current logic is protected so that future features,
> fixes, or optimisations will not cause regressions from the current
> behaviour.
> I'd like the thank the PSC once again for accepting this funding
> request (and the sponsors who made it possible!). In my opinion this
> was a crucial piece of work required to help make future QGIS releases
> much less likely to suffer serious regressions, so I'm very thankful
> that you allowed it to happen!
> Regards,
> Nyall
> [1] https://github.com/qgis/QGIS/pull/5254
> Qgis-psc mailing list
> Qgis-psc at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-psc
Links:
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170926/9a6a38be/attachment-0001.html>
