[QGIS-Developer] QGIS 3 Print Composer - Page Properties
Andreas Neumann
a.neumann at carto.net
Mon Apr 2 13:00:52 PDT 2018
Hi Calvin,
Same happened to me, some time ago. However, this issue is not so easy
to solve - because starting from version 3 you can mix different page
sizes in the same layout. In QGIS 2 all pages had to be of the same size.
If you have a good solution or proposal how to solve this UI wise,
please let us know.
Greetings,
Andreas
On 02.04.2018 21:56, C Hamilton wrote:
> I was just going to ask what happened to the "Page Size" properties in
> the QGIS 3 print composer, but I stumbled upon it accidentally by
> right-mouse clicking on the page and selecting "Page Properties." This
> was not easily found. In the QGIS 2 print compose it is a part of the
> layout. In QGIS 3 I just lucked out.
> Could the page properties be more obvious to find? At lease add them
> to the Layout or Edit menus or put them back under the layout settings.
> Thanks,
> Calvin
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180402/ef0d49d7/attachment.html>
