[QGIS-Developer] Problem with 3D during compilation in debian sid
matteo matteo.ghetta at gmail.com
Tue Apr 10 05:18:46 PDT 2018
Hi guys,
sorry sorry to bother the list you again with this, but I'm stack and
maybe someone has a quick solution.
I have a really fresh installation of debian unstable, so all the Qt
dependencies should be satisfied for the 3D.
However, if I enable the WITH3D flag in ccmake I'm not able to configure
it even if I have all the libqt5 installed (also libqt53dextras).
If someone has a solution or some suggestions for this it would be
really great
Thanks to all
Matteo
  CMake Error at
/usr/lib/x86_64-linux-gnu/cmake/Qt53DExtras/Qt53DExtrasConfig.cmake:27
(message):
   The imported target "Qt5::3DExtras" references the file
      "/usr/include/x86_64-linux-gnu/qt5/Qt3DExtras"
   but this file does not exist.  Possible reasons include:
   * The file was deleted, renamed, or moved to another location.
   * An install or uninstall procedure did not complete successfully.
   * The installation package was faulty and contained
      "/usr/lib/x86_64-linux-gnu/cmake/Qt53DExtras/Qt53DExtrasConfig.cmake"
   but not all the files it references.
 Call Stack (most recent call first):
/usr/lib/x86_64-linux-gnu/cmake/Qt53DExtras/Qt53DExtrasConfig.cmake:63
(_qt5_3DExtras_check_file_exists)
   CMakeLists.txt:310 (FIND_PACKAGE)
More information about the QGIS-Developer mailing list
