[QGIS-Developer] Error with GRASS in Processing
Nyall Dawson
nyall.dawson at gmail.com
Tue Apr 17 13:49:24 PDT 2018
On 17 April 2018 at 18:23, matteo <matteo.ghetta at gmail.com> wrote:
> Hi devs,
> testing GRASS within Processing I noticed a small bug in all the
> algorithms where you can add a map point coordinates with a click on the
> map, like r.viewshed, r.drain
> If the users choose to click on the map to fill the box with the
> coordinates of the point, the box is filled with both coordinates AND
> the additional EPSG information, like:
> 348403.62350233766,4903994.026987238 [EPSG:32632]
> and this makes GRASS unhappy.
> Should I fill a ticket?
I can't confirm this - for me it works fine with r.drain and the param
values including the CRS.
Can you post more steps to reproduce? The processing log would help.
Nyall
> Thanks
> Matteo
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
